The traffic filter on ExtremeSwitching series switches can be defined based on one of the following criteria:
Ingress—Mirrors traffic received at the port.
Egress—Mirrors traffic sent from the port.
Ingress and egress—Mirrors traffic either received at the port or sent from the port.
If you omit the optional parameters, all traffic is forwarded; the default for port-based mirroring is ingress and egress.
You can create an instance where the source is ingress only. When you add a source, pay attention to the monitor port.VLAN—All packets ingressing any port on a particular VLAN, regardless of the physical port configuration, is copied to the monitor port(s).
Virtual port—All traffic ingressing the switch on a specific VLAN and port combination is copied to the monitor port(s).
ExtremeSwitching series switches support a maximum of 128 mirroring filters per instance.
ExtremeXOS supports up to 16 monitor ports for one-to-many mirroring.
In normal mirroring, a monitor port cannot be added to a load share group. In one-to-many mirroring, a monitor port list can be added to a load share group, but a loopback port cannot be used in a load share group.
Two packets are mirrored when a packet encounters both an ingress and egress mirroring filter.
The configuration of remote-tag does not require the creation of a VLAN with the same tag; on these platforms the existence of a VLAN with the same tag as a configured remote-tag is prevented. This combination is allowed so that an intermediate remote mirroring switch can configure remote mirroring using the same remote mirroring tag as other source switches in the network. Make sure that VLANs meant to carry normal user traffic are not configured with a tag used for remote mirroring.
When a VLAN is created with remote-tag, that tag is locked and a normal VLAN cannot have that tag. The tag is unique across the switch. Similarly if you try to create a remote-tag VLAN where remote-tag already exists in a normal VLAN as a VLAN tag, you cannot use that tag and the VLAN creation fails.
