Displays inline power status information for the specified PoE switch.
| fast | Specifies showing fast PoE power status, which is the ability to provide power to devices at the time of switch power on without waiting for boot up based on last saved PoE state. |
| perpetual | Specifies showing perpetual PoE power status, which is the ability to preserve PoE power delivery to devices during reboot. Perpetual PoE is a switch-wide setting. |
N/A.
The output varies depending on the PoE device you are using.
The following command displays inline power status for the switch:
# show inline-power Inline Power System Information Configured : Enabled Power Usage Threshold : 70 percent Firmware Status Power (Watts) Power (Watts) Legacy Operational 405 W 0 W Disabled
# show inline-power fast
State Enable Disconnect Last Fast Boot Status
HW Disabled Deny-port Disabled
Cfg Disabled Deny-port
State: (HW) Hardware state per-slot, (Cfg) Configured state per-slot.
Fast Boot Status:
Succeeded - Fast PoE boot succeeded and configuration matches.
Disabled - Fast PoE was disabled in hardware at boot time.
Mismatch - Fast PoE booted but the configuration in hardware
did not match the configuration file.
Failed - Fast PoE boot failed and PoE was reset.
# show inline-power perpetual Perpetual POE is Enabled
The following example displays power budget information (line 7):
# show inline-power
Disconnect Precedence : deny-port
Power Budget : Maximum
Budgeted Measured
Operational 490 W 5 W
This command was first available in ExtremeXOS 11.1.
The fast and perpetual PoE options were added in ExtremeXOS 30.3.
The budget option was added in ExtremeXOS 31.2.
This command is available on the switches listed in Extreme Networks PoE Devices.
The fast and perpetual options are only available on the ExtremeSwitching X465 and X435 series switches.
The budget option is only available on the ExtremeSwitching X450-G2 series switch.
