ACL Style Policy
Traditional ONEPolicy architecture uses a hierarchical approach to rule precedence where rule type dictates precedence. In addition, rule look-ups occur per role, per action type. This means, for example, that triggering a forward/drop rule without an explicit Class of Service (CoS) action results in applying the forward/drop action, and then continuing searching until a rule with CoS action matches. This hierarchical approach is implemented in hardware by maintaining one list for forward/drop actions, and one list for CoS actions. This implementation often results in underused resources, because not every rule has both forward/drop and CoS actions.
With ACL Style Policy, a mode of operation with a single ordered list per role is maintained. Rule look-ups occur in the provided ACL order per role. A match applies all actions specified, and the search stops. This approach can potentially double the advertised scale of classification rules as compared to the traditional model. It also provides a more standard approach to policy classification rules.
Default policy rule-model is hierarchical, unless you are upgrading from ExtremeXOS 30.5 with a saved configuration that is set to access list.
For information about configuring ACL Style Policy, see Configuring ACL Style Policy.
SNMP for configuration of ACL Style Policy classification rules is not supported.
Traditional Versus ACL Style Policy Classification Rule Scaling
The following table compares the overall classification rule scale between "traditional" and ACL Style policy:
Table 1. Traditional versus ACL Style policy classification rule scaling
Switch Model(s)TraditionalACL Style**
4120Default: 184
Less System ACL: 184
Default: 440
Less System ACL: N/A
4220Default: 440
Less System ACL: 440
Default: 952
5120Default: 184
Default: 440
5320-48TDefault: 1,976
Less System ACL: 1,976
Default: 4,024
5320-24T-4X-XTDefault: 440
Default: 952
5320-24T-24S-4XE-XTDefault: 1,976
Default: 4,024
5320-16P*Default: 1,976
Default: 4,024
5420MDefault: 4,024
Less System ACL: 4.024
Default: 8,120
5420FDefault: 1,976
Default: 4,024
5520 Default: 4,024
Default: 8,120
5720-MW Default: 6,072
Less System ACL: 6,072
Default: 12,216
5720-MXW Default: 8,120
Less System ACL: 8,120
Default: 16,312
7520-48Y-8C Default: 1,976
Default: 3,512
7520-48XT-6CDefault: 1,976
Default: 3,512
7720-32CDefault: 1,976
Default: 3,512
* - 5320-16P models do not support MAC and IPv6 rules in traditional mode.
** - Applies to role-based DACLs as well as static ACLs created via the Policy CLI, which are also associated with a profile. User-based DACLs may achieve lower ACL Style numbers.
ACL Style Classification Rule Architecture
RESTful API Support
ACL Style Policy implements a new RESTful API for configuration of classification rules.
RESTful API is not supported for Dynamically-created ACLs via RADIUS and COA.
