Upgrading your ExtremeXOS image and modules uses the following process:
Beginning with ExtremeXOS 16.1, there are two methods available for the upgrade process:We recommend upgrading software images and any modular packages at the same time. The following example shows an ExtremeSwitching 5720 image onie-32.2.0.416.x86_64.xos being installed before rebooting the switch:
# show switch
SysName: 5720-48MW-SwitchEngine
SysLocation:
SysContact: https://www.extremenetworks.com/support/
System MAC: F4:CE:48:04:90:00
System Type: 5720-48MW-SwitchEngine
SysHealth check: Enabled (Normal)
Recovery Mode: All
System Watchdog: Enabled
Trusted Delivery: Boot Image Verified
Current Time: Wed Sep 14 19:58:24 2022
Timezone: [Auto DST Disabled] GMT Offset: 0 minutes, name is UTC.
Boot Time: Wed Sep 14 19:56:31 2022
Boot Count: 108
Next Reboot: None scheduled
System UpTime: 1 minute 52 seconds
Current State: OPERATIONAL
Image Selected: primary
Image Booted: primary
Primary ver: 32.2.0.414
Secondary ver: 32.2.0.414
Config Selected: primary.cfg
Config Booted: primary.cfg
Config Automatic: NONE (Disabled)
primary.cfg Created by Extreme Networks Switch Engine version 32.2.0.414
1031871 bytes saved on Tue Sep 13 21:20:10 2022
LAA MAC: Locally Administered MAC Address Disabled
# download image 10.127.4.103 onie-32.2.0.416.x86_64.xos secondary
Do you want to install image after downloading? (y - yes, n - no, <cr> - cancel) Yes
Downloading to Switch...........................................................................................................................................................................................................................................................................................
Installing to secondary partition!
Installing to Switch.................................................
This xos package does not include a switch diagnostics image and no diagnostics image is installed on the switch. Please download and install the diagnostics xmod with the download image command.
Image installed successfully
This image will be used only after rebooting the switch!
* (CIT_32.2.0.414) 5720-48MW-SwitchEngine.8 # reboot
Do you want to save configuration changes to currently selected configuration
file (primary.cfg) and reboot?
(y - save and reboot, n - reboot without save, <cr> - cancel command)
# reboot
The following example shows an ExtremeSwitching 5520 image summit_arm-32.2.0.416.xos being installed before rebooting the switch:
# show switch
SysName: 5520-48W-SwitchEngine
SysLocation:
System MAC: 00:04:96:EC:A4:00
System Type: 5520-48W-SwitchEngine
Recovery Mode: All
Current Time: Wed Sep 14 20:04:40 2022
Boot Time: Wed Sep 14 19:56:10 2022
Boot Count: 62
System UpTime: 8 minutes 30 seconds
Primary ver: 32.2.0.411
# show version detail
Switch : 800994-00-03 2008G-01290 Rev 03 BootROM: 2.2.1.11 IMG: 32.2.0.411
CPLD: 1.0.24 UC: 1.0.12
5520-VIM-4YE-1 : 800999-00-03 SB102011G-00319 Rev 03
Image : Extreme Networks Switch Engine version 32.2.0.411 by release-manager
on Mon 12 Sep 2022 01:36:37 AM UTC
BootROM : Default 2.2.1.11 Alternate 2.2.1.11
Diagnostics :
Certified Version : EXOS Linux 5.4.183, Extreme Networks FIPS Object Module 2.0.16a
Build Tools Version : exos-arm64-sdk-3.1.14.1.0
# download image 10.127.4.103 summit_arm-32.2.0.416.xos secondary
Installing to Switch........................................................................................................................................................................................................................................................
Bootrom versions are current.
# reboot
Section contents:
