User VRs are the VRs created by users in addition to the system VRs, and each user VR supports Layer 3 routing and forwarding.
The routing tables for each VR are separate from the tables for other VRs, so user VRs can support overlapping address space.
User VRs are supported only on the platforms listed for the VR feature in the Switch Engine v33.4.1 Licensing Guide document. When a SummitStack contains switches that do not support user VRs, the ports on those devices cannot be added to a user VR.
When using SNMPv2c for user created virtual-router, "read community" in the SNMP tool should be set as "vr_name@community_name" where vr-name is user created virtual router name . Similarly for SNMPv3, "Context name" in SNMP tool should be set as "vr_name@community_name" where vr-name is user created virtual router name .Section contents:
