Users are created by specifying a user name. Enabling the SNMPv3 user access allows an end
user to access the MIBs using SNMPv3 user. By deleting users access, the end-user is not
able to access the switch/MIBs using SNMPv3 user.
To create a user, use the following command:
configure snmpv3
add user [[hex
hex_user_name] | user_name] {authentication [md5 | sha] [hex
hex_auth_password | auth_password]} {privacy {des | aes {128 | 192 | 256}} [[hex
hex_priv_password] | priv_password]} }{volatile}
To display information about a user, or all users, use the
following command:
show snmpv3 user {[[hex hex_user_name] | user_name]}
To delete a user, use the following command:
configure snmpv3 delete user [all | [[hex
The SNMPv3 specifications describe the concept of a
security name. In the
ExtremeXOS implementation, the user name and security name are
identical. In this manual, both terms are used to refer to the same thing.
To configure SNMPv3 password policies for all users, use the following command:
configure snmpv3 user password-policy [authentication | privacy] [[username-match | char-repeat | long-sequence | char-validation][permit | deny] | history [num_passwords | duration
days | none] | min-length [num_characters | none]]
To display information about configured password policies, use the following
command:
show snmpv3 user password-policy
