Daisy Chain
If you issue the show stacking command and see that the stack topology is a daisy chain, we strongly recommend that you reconfigure the stack to use a ring topology.
Here is a sample CLI output from show stacking showing that the stack is in a daisy chain.
 # show stacking
Stack Topology is a Daisy-Chain
This node is not in an Active Topology
Node MAC Address     Slot  Stack State  Role     Flags
*00:04:96:7d:fc:9a    -    Disabled      Master   ---
To solve a daisy-chain problem, follow these steps:
  1. Ensure that all stack cables are properly seated and that the Link LED is illuminated on each stack port.
  2. Ensure that each stack node meets the following conditions:
  3. Wait for all stack nodes to finish booting and get through AAA login.
  4. Enter show stacking to verify that all stack nodes are connected in a ring topology.
  5. Check that the stacking port LEDs show as active on all nodes.
  6. Reconnect the stacking cables.
