The boundary clock node is configured to synchronize with the grandmaster node.
The grandmaster clock‘s IP address is added as “unicast-master” in the boundary clock node. The ptp_gm VLAN‘s configuration depends on the grandmaster for properties such as tag, or IP.
For boundary clocks, the End-to-End Transparent clock configuration must be applied on the egress ports through with the grandmaster and the ordinary/boundary clocks are reachable.create vlan ptp_gm configure vlan ptp_gm tag 40 configure vlan ptp_gm add port 1 untagged configure vlan ptp_gm ipaddress 192.168.10.5/24 enable ipforwarding ptp_gm create vlan ptp_slaves configure vlan ptp_slaves tag 100 configure vlan ptp_slaves add port 4 tagged configure vlan ptp_slaves ipaddress 192.168.5.1/24 enable ipforwarding ptp_slaves create network-clock ptp boundary configure network-clock ptp boundary add vlan ptp_gm one-step slave-only configure network-clock ptp boundary add vlan ptp-slaves one-step master-only configure network-clock ptp boundary add unicast-master 192.168.10.1 ptp-gm enable network-clock ptp boundary
Loopback IP interface is not added as a PTP clock port. A minimum of two clock ports must be configured for Boundary clock operation. A maximum of 32 PTP clock ports can be configured in Boundary clock.
