entry map {
if {
protocol udp;
destination-port 4789;
then {
qosprofile qp3;
replace-dscp;
replace-dot1p;
configure diffserv replacement qp3 code-point 32
As indicated in the example above, the dot1p value can also be replaced. In the absence of the ACL, VXLAN gateway copies the tenant dot1p value to the network. The replacement happens on the outer headers as the example above illustrates. QoS examination (dot1p or diffserv) happens on the first header. On the tenant port, it is examining the ethernet and IP header of tenant frames. On the network port, it is examining the outer Ethernet and IP header. There is no change to the existing support for treatment of packets, such as rate-limiting and queuing.
Section contents:
