Starting with ExtremeXOS 31.1, you can use Anycast RP without MSDP using the Anycast RP Using PIM (RFC 4610) feature.In an anycast RP topology, all RPs in a PIM-SM domain are configured with the same IP address on a loopback VLAN. The loopback VLAN IP address should have a 32-bit mask, so that it specifies a host address. All the routers within the PIM-SM domain select the nearest RP for each source and receiver. If the senders and receivers within the PIM-SM domain are distributed evenly, the number of senders that register with each RP is approximately equal.
Another requirement of the anycast RP topology is that MSDP must run on all RPs in the PIM-SM domain, so all RPs are also MSDP peers. We recommend that you configure an MSDP mesh connection between all MSDP peers in the domain.
Whenever any multicast source becomes active, this information is sent in an MSDP SA message to the other MSDP peers in the domain, announcing the presence of the source. If any RP within the domain fails, the IP routing protocol mechanism ensures that next available RP is chosen. If a sender registers with one RP and a receiver joins another RP, the information shared through MSDP enables PIM-SM to establish an SPT between the receiver and the source.
We recommend that you configure anycast RP peers in a mesh topology.To configure anycast RP, do the following at each anycast RP router:
create vlan vlan_name {tag tag } {description vlan-description } {vr name }
enable loopback-mode vlan vlan_name
The anycast RP address must be unique to the loopback VLAN and be the same on all anycast RP peers. It must not match the router IP address, the PIM BSR address, or any other IP addresses used by the router or any other network devices.enable ipforwarding {ipv4 | broadcast} {vlan vlan_name}
enable ipmcforwarding {vlan name}
configure ospf add vlan vlan-name area area-identifier link-type [auto | broadcast | point-to-point] {passive}
configure rip add vlan [vlan_name | all]
configure isis add [vlan all | {vlan} vlan_name] area area_name {ipv4 | ipv6}
configure pim {ipv4 | ipv6} add vlan [vlan-name | all] {dense | sparse} {passive}
configure pim {ipv4 | ipv6} crp static ip_address [none | policy] {priority [0-254]}
create msdp peer remoteaddr {remote-as remote-AS} {vr vrname}
configure msdp peer [remoteaddr | all] password [none | {encrypted} tcpPassword] {vr vrname}
configure msdp peer remoteaddr description {peer-description} {vr vrname}
enable msdp [{peer} remoteaddr | peer all] {vr vr_name}
enable msdp {vr vrname}
