Available Stacking Methods
Each switch model can use various methods of stacking.
SummitStacking by Stacking Method shows the switch models that can participate in each stacking method.
Table 1. SummitStacking by Stacking Method
Stacking Method Speed per Link (HDX) Cable Type and Lengths Switch Models
SummitStack-V10 Gbps 0.5 m - 40 km
SFP+ (with SR, LR, and ER)
5520 (using 5520-VIM-4X)
Note: The 5520 switches can stack with 5320 switches or 5420 switches by installing a 5520-VIM-4X into the 5520 switches.
SummitStack-V4010 Gbps0.5 m - 40 km
4220 (ports U1, U2)
Note: The 4220 switches can only stack with themselves.
5320
Note: The 5320 switches can stack with themselves, the 5420 or 5520 switches using 5520-VIM-4X ports.
5320-24T-4X-XT and 5320- 24T-24S-4XE-XT (ports U1, U2)
Note: 5320-24T-4X-XT and 5320- 24T-24S-4XE-XT switches can only stack with themselves.
Note: 5320-16P-2MXT-2X can stack with other 5320 switches except 5320-24T-4X-XT and 5320-24T-24S-4XE-XT switches.
5420 (ports U1, U2)
Note: The 5420 switches can stack with themselves, 5320 switches, or 5520 switches using 5520-VIM-4X ports.
SummitStack-V8020 Gbps0.5 m - 5 m SFP-DD 5420 (ports U1, U2)
Note: The 5420 switches can stack with themselves and 5520 (ports U1 and U2) when configured for SummitStack-V80.
SummitStack-V10025 Gbps0.5 m - 40 m
SFP28 only (with SR, LR, and ER)
5120 (ports U1, U2)
Note: The 5120 switches can only stack with themselves.
SummitStack-V16040 Gbps 0.5 m - 40 kM
QSFP+ only
5520 (ports U1, U2)
Note: If you use SummitStack-V160, 5520 switches can stack only with themselves. To stack with 5320 and 5420 switches, the 5520 can use either SummitStack-V80 on ports U1 and U2 or SummitStack-V on the alternate stack ports (Using a 5520-VIM-4X).
SummitStack-V20050 Gbps0.5 m - 5 m
QSFP28 only
4120 (ports U1, U2)
Note: The 4120 switches can only stack with themselves.
5120-44X-4Y-2C (ports 49, 50)
5520 (ports U1, U2)
Note: If you use SummitStack-V200, 5520 switches can stack only with themselves or 5720 switches.
SummitStack-V400106 Gbps0.5 m - 5 m
QSFP28 only
5720 (ports U1, U2), Extreme 7520 (ports 53/54 or 55/56), or 7720 (ports 31, 32)
Note: If you use SummitStack-V400, 5720 switches can only stack with themselves.
Note: No VIM ports can be configured as stack ports for 5720 switches.
Note: If you use SummitStack-V400, 7520 and 7720 switches can only stack with themselves.
SummitStack-V400 Alternative Configuration100 GbpsV400 Alternative Configuration is required when using specific fiber cables. This mode sets the stack ports to 100G, enables pre-emphasis, and FEC (clause_91).
  • QSFP28 SR4
  • QSFP28 LR4
  • QSFP28 CWDM4
  • QSFP28 PSM4
  • QxQ AOC cable - 5m
  • QxQ AOC cable - 7m
  • QxQ AOC cable - 10m
  • QxQ AOC cable - 20m
Note: If you use SummitStack-V400 Alternative Configuration, 5720 switches can only stack with themselves.
Note: If you use SummitStack-V400 Alternative Configuration, 7520 and 7720 switches can only stack with themselves.
For more details about the stacking methods that are available for each switch series, see the hardware installation guide for your switch.
All switches in the stack must run the same version of Switch Engine.
