On ExtremeSwitching series switches, if a switch runs outside the expected range, the
switch logs an error message, generates a trap, and one of the following actions occurs:
On a SummitStack slots, the reset/none option from configure sys-recovery-level [all | none]
command determines the action that
occurs.
For all switches, only a warning is
logged and the switch continues to run with the system state as "overheat." If the
temperature increases further into overheat condition, after the operating temperature
exceed a further higher temperature, the hardware resets the switch.
