create esrp
create esrp esrp_domain {type [vpls-redundancy | standard]}
Description
Creates an ESRP domain with the specified name on the switch.
Syntax Description
esrp_domain Specifies the name of an ESRP domain to be created. Can be up to 32 characters in length.
Default
The ESRP domain is disabled and in the “Aware” state.
When you create an ESRP domain, it has the following default parameters:
  • Operational version—Extended
  • Priority—0
  • VLAN interface—none
  • VLAN tag—0
  • Hello timer—2 seconds
  • Neighbor timer—8 seconds
  • Premaster timer—6 seconds
  • Neutral timer—4 seconds
  • Neighbor restart timer—30 seconds
  • VLAN tracking—none
  • Ping tracking—none
  • IP route tracking—none
Usage Guidelines
The type keyword specifies the type of ESRP domain when a new ESRP domain is created. The only types supported are vpls-redundancy and standard. Not specifying the optional ESRP domain type results in the creation of an ESRP domain of type standard. The standard ESRP domain is equivalent to the legacy ESRP domain type that was implicitly created. The vpls-redundancy domain type is only specified when redundant access to an MPLS VPLS network is desired.
An ESRP domain name must begin with an alphabetical character and may contain alphanumeric characters and underscores ( _ ), but it cannot contain spaces. The maximum allowed length for a name is 32 characters. For ESRP domain name guidelines and a list of reserved names, see Object Names in the Switch Engine v33.4.1 User Guide .
Each ESRP domain name must be unique and cannot duplicate any other named ESRP domains on the switch. If you are uncertain about the ESRP names on the switch, use the show esrp command to view the ESRP domain names.
You can create a maximum of 128 ESRP domains.
For an Extreme Networks switch to be ESRP-aware, you must create an ESRP domain on the aware switch, add a master VLAN to that ESRP domain, add a member VLAN to that ESRP domain if configured, and configure a domain ID if necessary.
For complete information about software licensing, including how to obtain and upgrade your license and what licenses are appropriate for this feature, see the Switch Engine v33.4.1 Licensing Guide document.
The following command creates ESRP domain esrp1 on the switch:
create esrp esrp1
This command was first available in ExtremeXOS 11.0.
Platform Availability
