install bootrom
install bootrom [from-image | fname | local-file] {slot slot-number} {reboot}
Description
Installs a new version of the ExtremeXOS BootROM image.
Syntax Description
from-image Specifes using BootROM image packaged in the booted software image.
fname Specifies the BootROM image file name of previously downloaded image.
local-file Specifies using a BootROM image file on a local file path (USB is /usr/local/ext, internal memory is /usr/local/tmp, and home directory is /usr/local/cfg).
slot For SummitStacks, specifies installing the BootROM image on a particular node (slot).
slot-number On a SummitStack, selects which node the BootROM image should be installed on.
reboot Reboots the switch after the image is installed.
Default
N/A.
Usage Guidelines
When you download a BootROM image (download bootrom [[ipaddress | hostname] filename {{vr} vrname} {block-size block_size}] {slot slotid} {install} {reboot}}), you are prompted to install the image immediately after the download is finished. If you choose to install the image at a later time, you can use this command to install the software on the switch.
The BootROM image file is designated with a .xtr file extension.
Displaying the BootROM Versions
To display the BootROM version for the switch, use the show version command.
Local File Name Character Restrictions
When specifying a local or remote file name, the switch permits only the following characters:
SummitStack Only
You can run this command only from the master node.
The following example installs the previously downloaded BootROM image file summitX-1.0.1.5-bootrom.xtr:
# install bootrom summitX-1.0.1.5-bootrom.xtr
The following messages appear:
Installing bootrom...
Writing bootrom...
Verifying Flash contents...
bootrom written.
Bootrom installed successfully
The following example installs the bootROM image file uboot.xtr located on the local file system at /usr/local/tmp/:
# install bootrom /usr/local/tmp/uboot.xtr
Downloading to Switch.
Bootrom installed successfully.  It will be used on the next reboot.
This command was first available in ExtremeXOS 11.0.
Support for SummitStack was added in ExtremeXOS 12.0.
The local-file option was added in ExtremeXOS 30.7.
The from-exos option was removed in ExtremeXOS 31.5.
The from-image option was added in ExtremeXOS 31.5.
Platform Availability
and stacks.
