save debug tracefiles
save debug tracefiles directory_path
Description
Copies debug information to USB 2.0 storage device.
Syntax Description
directory_pathDirectory path (memory card is /usr/local/ext; internal memory is /usr/local/tmp; and home directory is /usr/local/cfg.
Default
N/A.
Usage Guidelines
Use this command only under the guidance of Extreme Networks Technical Support to troubleshoot the switch.
Use this command to copy debug information to an installed removable storage device. The debug information includes log files and trace files.
Progress messages are displayed that indicate the file being copied and when the copying is finished.
Beginning with ExtremeXOS 11.6, you can use the upload debug [hostname |ipaddress] {{vr}vrname} command to copy debug information to a network TFTP server.
The following command copies debug information to a removable storage device:
# save debug tracefiles /usr/local/ext
This command was first available in ExtremeXOS 11.0.
The syntax for this command was modified in ExtremeXOS 11.1 from upload debug-info memorycard to save debug tracefiles memorycard.
Support for USB 2.0 storage devices was added in ExtremeXOS 12.5.3.
The option memorycard was removed and the variable directory_path was added in ExtremeXOS 30.3.
Platform Availability
