A network group alias is a set of configurations consisting of host and network configurations. Network configurations are complete networks in the form of 192.168.10.0/24 or an IP address range in the form of 192.168.10.10-192.168.10.20. Host configurations are in the form of a single IP address, 192.168.10.23.
A network group alias can contain multiple definitions for a host, network, and IP address range. A maximum of eight (8) host entries, eight (8) network entries and eight (8) IP addresses range entries can be configured inside a network group alias. A maximum of 32 network group alias entries can be created.
A network group alias can be used in IP firewall rules to substitute hosts, subnets and IP address ranges.To edit or delete a network alias configuration:
| Name | Displays the administrator assigned name associated with the network group alias. |
| Host | Displays all the host aliases in the listed network group alias. Displays a blank column if no host alias is defined. |
| Network | Displays all network aliases in the listed network group alias. Displays a blank column if no network alias is defined. |
