To define a dynamic routing area configuration:
Select the Area Settings tab.
An OSPF Area contains a set of routers exchanging LSAs (Link State Advertisements) with others in the same area. Areas limit LSAs and encourage aggregate routes.
Review the following Area Setting configurations to determine if a new configuration needs to be added or existing settings warrants modifications:
| Area ID |
Displays either the IP address or integer representing the OSPF area. |
| Authentication Type |
Lists the authentication (user validation) types used to validate and authenticate the credentials of the dynamic route connections. |
| Type |
Lists the OSPF area type in each listed configuration. |
Print
this page
Email this topic
Feedback
