The Device screen displays basic information about a selected access point. Use this screen to gather version information, boot image utilization and upgrade status. An access point's sensor server capability, power management and system resources can also be administrated from the Device screen.
To view the device statistics:
| Model Number |
Displays the model of the selected access point to help distinguish its exact SKU and country of operation. |
| Serial Number |
Displays the numeric serial number set for the access point. |
| Version |
Displays the software (firmware) version on the access point. Use this information to assess whether a firmware upgrade would enhance the access point's support capability. |
| Boot Partition |
Displays the boot partition type. |
| Fallback Enabled |
Displays whether this option is enabled. This method enables a user to store a known legacy version and a new version in device memory. The user can test the new software, and use an automatic fallback, which loads the old version on the access point if the new version fails. |
| Fallback Image Triggered |
Displays whether the fallback image was triggered. The fallback image is an old version of a known and trusted operational firmware image stored in device memory. This allows a user to test a new version of firmware. If the new version fails, you can use the old version to ensure the access point's duty cycle is maintained. |
| Next Boot |
Designates this version as the version used the next time the access point is booted. |
| Available Memory (MB) |
Displays the available memory (in MB) available on the access point. |
| Total Memory (MB) |
Displays the access point's total memory. |
| Currently Free RAM |
Displays the access point's free RAM space. If its very low, free up some space by closing some processes. |
| Recommended RAM |
Displays the recommended RAM required for routine operation. |
| Current File Description |
Displays the access point's current file description. |
| Maximum File Description |
Displays the access point's maximum file description. |
| CPU Load 1 Minute |
Lists this access point's CPU utilization over a 1 minute span. |
| CPU Load 5 Minutes |
Lists this access point's CPU utilization over a 5 minute span. |
| CPU Load 15 Minutes |
Lists this access point's CPU utilization over a 15 minute span. |
| Number |
Displays the number of fans supported on the listed access point. access point models each have unique fan support. |
| Speed (Hz) |
Displays the fan speed in Hz. |
| Number |
Displays the number of temperature elements (gauges) used by the access point. |
| Temperature |
Displays the current temperature (in Celsius) to assess a potential access point overheat condition. |
| Buffer Size |
Lists the sequential buffer size. |
| Current Buffers |
Displays the current buffers available to the selected access point. |
| Maximum Buffers |
Lists the maximum buffers available to the selected access point. |
| IP Domain Name |
Displays the name of the IP Domain service used with the selected access point. |
| IP Domain Lookup state |
Lists the current state of an IP lookup operation. |
| Name Server |
Displays the names of the servers designated to provide DNS resources to this access point. |
| Type |
Displays the type of server for each server listed. |
| Primary Build Date |
Displays the build date when this access point firmware version was created. |
| Primary Install Date |
Displays the date this version was installed. |
| Primary Version |
Displays the primary version string. |
| Secondary Build Date |
Displays the build date when this version was created. |
| Secondary Install Date |
Displays the date this secondary version was installed. |
| Secondary Version |
Displays the secondary version string. |
| FPGA Version |
Displays whether a FPGA supported firmware load is being utilized. |
| PoE Firmware Version |
Displays whether a PoE supported firmware load is being utilized. |
| Sensor Lock |
Displays whether a lock has been applied to access point sensor capabilities. Keeping an access point from performing sensor support ensures client support is continuously maintained. |
| Upgrade Status |
Displays the status of the image upgrade. |
| Upgrade Status Time |
Displays the time of the image upgrade. |
| Power Management Mode |
Displays the power mode currently invoked by the selected access point. |
| Power Management Status |
Lists the power status of the access point. |
| Ethernet Power Status |
Displays the access point's Ethernet power status. |
| Radio Power Status |
Displays the power status of the access point's radios. Each access point radio is capable of having a unique, administrator defined, transmit capability. |
| Hop Limit |
Lists the maximum number of times IPv6 traffic can hop. The IPv6 header contains a hop limit field that controls the number of hops a datagram can be sent before being discarded (similar to the TTL field in an IPv4 header). |
