A network group alias is a set of configurations that consist of host and network configurations. Network configurations are complete networks in the form 192.168.10.0/24 or IP address range in the form 192.168.10.10-192.168.10.20. Host configuration is in the form of single IP address, 192.168.10.23.
A network group alias can contain multiple definitions for host, network, and IP address range. A maximum of eight (8) host entries, eight (8) network entries and eight (8) IP addresses range entries can be configured inside a network group alias. A maximum of 32 network group alias entries can be created.
A network group alias is used in IP firewall rules to substitute hosts, subnets and IP address ranges:
To edit or delete a network alias configuration:
| Name | Displays the administrator assigned name of the network group alias. |
| Host | Displays all host aliases configured in this network group alias. Displays a blank column if no host alias is defined. |
| Network | Displays all network aliases configured in this network group alias. Displays a blank column if no network alias is defined. |
