You can add a location policy or manage existing policies to match your requirements.
To edit, copy, rename, or replace an existing policy, select the policy and click Edit, Copy, Rename or Replace respectively.
| Enable | By default the policy is enabled and the value displays as true. |
| Location Key | Enter your 64-bit ExtremeLocation tenant API key. This is
the key the controller/virtual controller uses to
authenticate with the ExtremeLocation server. Note: You can
generate the API-Key from the ExtremeLocation UI. For
more information, refer to the ExtremeLocation user
guide, available at https://extremenetworks.com/documentation.
| Server ID | Set the server host ID number. Currently only one ExtremeLocation server can be configured. | |
| Server IP | Configure the ExtremeLocation server's hostname of IP address. |
![]() Note Specify the server hostname and not the IP address, as the IP address is likely to change periodically in order to balance load across multiple location server instances. |
| Server Port | Set the port on which the ExtremeLocation server is reachable. Select the port from 1 - 65535. |
![]() Note By default the ExtremeLocation server is reachable on port 443. |
