To view mesh point statistics for RF Domain member APs and their connected clients:
The System node expands to display the RF Domains created within the managed network.
The RF Domain statistics menu displays in the right-hand side of the screen, with the Health tab selected by default.
The MCX Geographical View screen displays by default.
The Device Data Transmit screen displays.
| Data Bytes (Bytes): Transmitted Bytes | Displays the total amount of data, in Bytes, transmitted by Mesh Points in the RF Domain. |
| Data Bytes (Bytes): Received Bytes | Displays the total amount of data, in Bytes, received by Mesh Points in the RF Domain. |
| Data Bytes (Bytes): Total Bytes | Displays the total amount of data, in Bytes, transmitted and received by Mesh Points in the RF Domain. |
| Data Packets Throughput (Kbps): Transmitted Packets | Displays the total amount of data, in packets, transmitted by Mesh Points in the RF Domain. |
| Data Packets Throughput (Kbps): Received Packets | Displays the total amount of data, in packets, received by Mesh Points in the RF Domain. |
| Data Packets Throughput (Kbps): Total Packets | Displays the total amount of data, in packets, transmitted and received by Mesh Points in the RF Domain. |
| Data Rates (bps): Transmit Data Rate | Displays the average data rate, in kbps, for all data transmitted by Mesh Points in the RF Domain. |
| Data Rates (bps): Receive Data Rate | Displays the average data rate, in kbps, for all data received by Mesh Points in the RF Domain. |
| Data Rates (bps): Total Data Rate | Displays the average data rate, in kbps, for all data transmitted and received by Mesh Points in the RF Domain. |
| Packets Rate (pps): Transmitting Packet rate | Displays the average packet rate, in packets per second, for all data transmitted and received by Mesh Points in the RF Domain. |
| Packets Rate (pps): Received Packet rate | Displays the average packet rate, in packets per second, for all data received and received by Mesh Points in the RF Domain. |
| Packets Rate (pps): Total Packet Rate | Displays the average data packet rate, in packets per second, for all data transmitted and received by Mesh Points in the RF Domain. |
| Data Packets Dropped and Errors: Tx Dropped | Displays the total number of transmissions that were dropped Mesh Points in the RF Domain. |
| Data Packets Dropped and Errors: Rx Errors | Displays the total number of receive errors from Mesh Points in the RF Domain. |
| Broadcast Packets: Tx Bcast/Mcast Pkts | Displays the total number of broadcast and multicast packets transmitted from Mesh Points in the RF Domain. |
| Broadcast Packets: Rx Bcast/Mcast Pkts | Displays the total number of broadcast and multicast packets received from Mesh Points in the RF Domain. |
| Broadcast Packets: Total Bcast/Mcast Pkts | Displays the total number of broadcast and multicast packets transmitted and received from Mesh Points in the RF Domain. |
| Management Packets: Transmitted by the node | Displays the total number of management packets that were transmitted through the Mesh Point node. |
| Management Packets: Received by the node | Displays the total number of management packets that were received through the Mesh Point node. |
| Management Packets: Total Through the domain | Displays the total number of management packets that were transmitted and received through the Mesh Point node. |
| Data Indicators: Traffic Index | Displays True of False to indicate whether or not a traffic index is present. |
| Data Indicators: Max User Rate | Displays the maximum user throughput rate for Mesh Points in the RF Domain. |
| Data Distribution: Neighbor Count | Displays the total number of neighbors known to the Mesh Points in the RF Domain. |
| Data Distribution: Neighbor Count | Displays the total number of neighbor radios known to the Mesh Points in the RF Domain. |
