Configure Description on Port Channel
Configure “description” per EFA port-channel which gets configured on SLX port-channel. The default value of po “description” is “EFA Port-channel <efa-po-name>”. You can configure PO “description” during po create and po update operations.
When you upgrade from EFA 2.3.2 to EFA 2.4.0 or EFA 2.5.0, all the POs contains the default “description” and is displayed as part of efa tenant po show --detail.
  1. Configure Description during Port-Channel Create.
    efa tenant po create --name <po-name> --tenant <tenant-name> --description <po-description>
                   --speed <100Mbps|1Gbps|10Gbps|25Gbps|40Gbps|100Gbps> --negotiation <active|passive|static>
    	--port <list-of-po-members> --min-link-count <min-link-count> --number <po-number> --lacp-timeout <short|long>
  2. Configure Description during Port-Channel Update.
    efa tenant po update --name <po-name> --tenant <tenant-name>
                  --operation <port-add|port-delete|lacp-timeout|description|min-link-count>
                  --port <list-of-po-members> --lacp-timeout string <short|long> --min-link-count <min-link-count>
    efa tenant po create --name ten1po1 --tenant ten1 --port 10.20.246.15[0/1],10.20.246.16[0/1] --speed 10Gbps --negotiation active --description tenant1po1
    efa tenant po create --name ten1po2 --tenant ten1 --port 10.20.246.15[0/2],10.20.246.16[0/2] --speed 10Gbps --negotiation active
    efa tenant po update --name ten1po1 --tenant ten1 --operation description --description tenat1po1changed
    efa tenant po show --name ten1po1 --tenant ten1 --detail
    efa tenant po show --name ten1po2 --tenant ten1 --detail
    Tenant          : ten1
    Description     : tenat1po1changed
    Speed           : 10Gbps
    Negotiation     : active
    Min Link Count  : 1
    Lacp Timeout    : long
    Ports           : 10.20.246.15[0/1]
                    : 10.20.246.16[0/1]
    State           : po-created
    Dev State       : provisioned
    App State       : cfg-in-sync
    Tenant          : ten1
    Description     : EFA Port-channel ten1po2
    Speed           : 10Gbps
    Min Link Count  : 1
    Lacp Timeout    : long
    Ports           : 10.20.246.15[0/2]
                    : 10.20.246.16[0/2]
    State           : po-created
