Return Material Authorization
	With the Return Material Authorization (RMA) process, you can replace a faulty device
		with a new device that has the same configuration.
		The high-level process is as follows. For specific steps and commands, see Replace a Faulty Device.
			- Verify prerequisites.
					- Periodic configuration backup
						must be enabled on all devices that may need RMA. This prerequisite ensures
						that you have the latest configuration file to be used for recovery.
					- Maintenance mode must be
						enabled upon reboot on all devices.
			- Remove the faulty device and replace it with
				the new device. Ports on this device must be administratively up and online.
The
					ports on the new device must have the same connections as the old device. For
					example, if the old device ethernet port1 and port2 went to port3 and port4 of
					another device, the new replacement device must have these exact same ethernet
					port connections.
			- Configure the new device with the same
				management IP address and credentials as the old device.
			- Start the RMA process from the command line or
				with the REST API.
As a best
					practice, run the
efa
						inventory rma execute command with the configuration backup ID so
					that the configuration is properly restored. If you run the command without the
					backup ID, you must manually update the configuration on the new
					device.
During the RMA process, the following actions occur:
						- The device boots up in
							maintenance mode.
						- EFA updates the device ID
							for the connection details in the database.
						- Maintenance mode is
							initiated if the device is not already in maintenance mode.
						- EFA replays the
							backed-up configuration specified by the
config-backup-id parameter of the efa inventory rma
								execute command.
						- EFA begins the
							drift reconcile process, which involves device discovery, device update,
							and fabric and tenant reconciliation. For more information, see Drift and Reconcile.
If the RMA
								command fails during this stage, you can manually run the drift
								reconcile process from the CLI. If the RMA process fails for any
								other reason, restart the RMA process.
						- When drift reconcile is
							complete, the device is taken out of maintenance mode.
						- During the RMA process,
							EFA health checks are deactivated and RASlog does not trigger drift
							reconcile.
			- Install the HTTPS or OAuth2 certificate on the
				new device.
The following conditions result in the RMA
			process failing:
				- If there is mismatch in device IP
					and credentials
				- If the device maintenance mode is
					not successful
In both the conditions, reject the device replacement with the new
			device.
