Enable Graceful Restart on Tenant VRF
You can enable graceful restart per tenant VRF during VRF create and VRF update operations. EFA provisions the user input graceful restart on the switches during the instantiation and update of VRF.
Based on the endpoints present in the EPG, VRF is instantiated on the switches when you trigger L3 endpoint group create or L2 endpoint group transition to L3 endpoint group.
VRF is updated on the switches when you trigger VRF update operation, based on the endpoints present in the endpoint groups using this VRF.
Currently, graceful restart is automatically configured when you configure the VRF.
  1. By default, graceful restart is disabled. Default value of graceful restart is the switch default.
  2. Pre-EFA 2.4.0 versions have graceful restart enabled by default.
  3. Upgrade from pre-2.4.0 to 2.4.x, and 2.5.0 retains the graceful restart enabled for all the pre-2.4.0 VRFs.
  1. To enable graceful restart when you create a tenant VRF, run the following command:
    efa tenant vrf create --name <vrf-name> --tenant <tenant-name>
                --graceful-restart=true/false
  2. To enable graceful restart on an existing tenant VRF, run the following command:
    efa tenant vrf update --name <vrf-name> --tenant <tenant-name>
                --operation graceful-restart-update --graceful-restart=true/false
    efa tenant vrf create --name vrf1 --tenant tenant1
    efa tenant vrf create –name vrf10 –tenant tenant1 –-graceful-restart=true
    efa tenant epg create --name ten1epg1 --tenant tenant1
               --port 10.24.80.134[0/11],10.24.80.135[0/11]
               --switchport-mode trunk –ctag-range 11 --vrf vrf1 –anycast-ip 11:10.10.11.1/24
    efa tenant epg create --name ten1epg2 --tenant tenant1
               --port 10.24.80.134[0/12],10.24.80.135[0/12]
               --switchport-mode trunk –ctag-range 12 --vrf vrf10 –anycast-ip 12:10.10.12.1/24
    efa tenant vrf update –-name vrf1 –-tenant tenant1
               --operation graceful-restart-update –-graceful-restart=true
    efa tenant vrf update --name vrf10 –-tenant tenant1
               --operation graceful-restart-update –graceful-restart=false
