You can use the EFA command line to replace a faulty device with a new device and
		maintain the configuration of the old device.
		Prerequisites:
			- Ensure that periodic configuration backup is enabled on all devices that may
				need RMA. This prerequisite ensures that you have the latest configuration file
				to be used for recovery.
			- Ensure that maintenance mode is enabled upon reboot on all devices.
		This procedure describes how to replace a faulty device as part of the Return
			Material Authorization (RMA) process. For more information, see Return Material Authorization.
				Obtain the configuration backup
					of the old device.
					# efa inventory config-backup execute --ip <ip-addr>
				This step generates a configuration backup ID that you use in step
					5.
				Replace the faulty device with
					the new device.
				Ensure that the ports of the new device are administratively up and
					online.
The ports on the new device must have the same connections as the old device.
					For example, if the old device ethernet port1 and port2 went to port3 and port4
					of another device, the new replacement device must have these exact same
					ethernet port connections.
				Configure the new device with the same management IP address and credentials as
					the old device.
				Start the RMA process.
					# efa inventory rma execute --ip <ip-addr> --config-backup-id <id>
As a best practice, run the command with
						the
--config-backup-id <id> option so that the configuration
						is properly restored. If you run the command without the backup ID, you must
						manually update the configuration on the new device.
				View the RMA history and
					detail.
					# efa inventory rma history -–ip <ip-addr>
# efa inventory rma detail –uuid <uuid>
				View the drift reconcile history
					and detail.
					# efa inventory drift-reconcile history -–device-ip <ip-addr>
# efa inventory drift-reconcile detail –-uuid <uuid>
				Install the HTTPS or OAuth2 certificate on the new device.
					# efa certificates device install --ips <device-ip-addr> --certType [https|token]
			 - Optional:
				Delete the RMA record.
					# efa inventory rma delete -–ip <ip-addr>
			 - Optional:
				Manually start the drift
					reconcile process if the RMA process fails during the drift reconcile stage.
					# efa inventory drift-reconcile execute --ip <ip-addr> –-reconcile
