The 5-stage topology has 3 layers of
		devices: leaf, spine, and super-spine.
		You can build a 5-stage Clos from top to
			bottom or bottom to top. The following example builds from top to bottom.
Tip
If any devices in a fabric are in "admin-down" state, use of the
				following commands in that same fabric will not add or delete devices in the fabric:
efa fabric device add-bulk and
efa fabric device
					remove.
				Create the fabric.
				Add a device to the
					fabric.
					A device must be registered with the Inventory Service before you can add it to a fabric.
						However, if you provide a user name and password when you run the command,
						then the devices are automatically registered with the Inventory Service.
						See the examples at the end of this procedure.
					You can add multiple devices by using the
						command. If you choose to add multiple devices in bulk, ensure you perform
						the following operations first:
							- Run the efa inventory
									device register --ip <list-of-device-ips>
								command.
									device interface list --ip <device-ip> command.
								In the output of the command, verify that the states of the port
								links are as you expected (in the Admin Status and Oper Status
								fields). If not, manually check the physical cabling and fix any
								issues. Then continue with the efa fabric device
									add-bulk operation.
				Configure the fabric.
Topology validation occurs
					during the addition of a device and during fabric configuration. The following
					validations are performed:
						- Leaf nodes must connect
							to all the spine nodes.
						- A spine node must connect
							to all the leaf nodes.
						- A border leaf node connects to all the
							spine nodes.
						- A spine node connects to all the border
							leaf nodes.
						- No more than two leaf
							nodes connect to each other.
						- No more than two border leaf nodes connect
							to each other.
						- Border leaf node and leaf
							node are not connected to each other.
						- Spine nodes are not
						- Super-spine nodes are not
						- A leaf node marked as
							"multi-homed" must have an MCT neighbor.
							"single-homed" is not connected to other leaf nodes.
						- A border leaf node marked as "multi-homed"
						- A border leaf node marked as "single-homed"
							is not connected to other border leaf nodes.
						- Device role (such as leaf, border-leaf,
							spine, and super-spine) is validated for a given device platform type
							(for example, SLX 9840 cannot be added as a leaf).
Tip
The
						validation process reports any errors as a response to the
efa fabric device
							add or
efa fabric configure operations. You can use the
efa fabric error
							show command to export these errors to a CSV file.
This example creates the
			fabric.
efa fabric create --name stage5
This example adds a device to the
			fabric.
efa fabric device add--name stage5 --username admin --password password
--leaf 10.20.50.205,10.20.50.206,10.20.50.207 --spine 10.20.50.203,10.20.50.204
--three-stage-pod podA --super-spine
This example adds multiple devices to the
			fabric.
efa fabric device add-bulk --name stage5 --username admin --password password
--three-stage-pod podA --super-spine 10.20.50.201,10.20.50.202 --five-stage-pod podC
This example configures the fabric
			topology.
efa fabric configure --name stage5
