Use the fabric settings to update BGP MD5 password using --md5-password and --md5-password-enable.
            Update the BGP dynamic peer listen limit using --bgp-dynamic-peer-listen-limit. A setting to denote a single rack or
            multi-rack deployment --single-rack-deployment is added under fabric setting. You can update
            these settings after fabric is configured.
For details on BGP MD5 Authentication, see Extreme Fabric Automation Security Guide, 2.5.0 .
The following is an example of output from the Rack Low Density L3 backup and efa fabric setting show --name --advanced command.
| Rack Low Density L3 backup | 0/30 | | port (not applicable to | | | SLX-9250) | | +--------------------------------+-----------------------------+ | Rack Low Density MCT Ports | 0/19,0/22 | +--------------------------------+-----------------------------+ | Configure Overlay Gateway | Yes | +--------------------------------+-----------------------------+ | VNI Auto Map | Yes | +--------------------------------+-----------------------------+ | Backup Routing Enable | Yes | +--------------------------------+-----------------------------+ | Backup Routing IPv4 Range | 10.40.40.0/24 | +--------------------------------+-----------------------------+ | Backup Routing IPv6 Range | fd40:4040:4040:1::/120 | +--------------------------------+-----------------------------+ | MD5 Password Enable | Yes | +--------------------------------+-----------------------------+ | MD5 Password | $9$9Yc+EqhoseRMPh9fDhk9TQ== | +--------------------------------+-----------------------------+ | BGP Dynamic Peer Listen Limit | 101 | +--------------------------------+-----------------------------+
# efa fabric setting show --name fabric1 --advanced +--------------------------------+-----------------------------+ | NAME | VALUE | +--------------------------------+-----------------------------+ | Fabric Name | fabric1 | +--------------------------------+-----------------------------+ | Link IP Range | 10.10.10.0/23 | +--------------------------------+-----------------------------+ | Loopback IP Range | 172.31.254.0/24 | +--------------------------------+-----------------------------+ | Loopback Port Number | 1 | +--------------------------------+-----------------------------+ | VTEP Loopback Port Number | 2 | +--------------------------------+-----------------------------+ | Rack ASN Block | 4200000000-4200065534 | +--------------------------------+-----------------------------+ | Rack Border Leaf ASN Block | 4200065535-4200065635 | +--------------------------------+-----------------------------+ | Single Rack Deployment | Yes | +--------------------------------+-----------------------------+ | P2P IP Type | numbered | +--------------------------------+-----------------------------+ | Any cast MAC | 0201.0101.0101 | +--------------------------------+-----------------------------+ | IPV6 Any cast MAC | 0201.0101.0102 | +--------------------------------+-----------------------------+ | MAC Aging Timeout | 1800 | +--------------------------------+-----------------------------+ | MAC Aging Conversational | 300 | | Timeout | | +--------------------------------+-----------------------------+ | MAC Move Limit | 20 | +--------------------------------+-----------------------------+ | Duplicate MAC Timer | 5 | +--------------------------------+-----------------------------+ | Duplicate MAC Timer MAX Count | 3 | +--------------------------------+-----------------------------+ | BFD Enable | Yes | +--------------------------------+-----------------------------+ | BFD Tx | 400 | +--------------------------------+-----------------------------+ | BFD Rx | 400 | +--------------------------------+-----------------------------+ | BFD Multiplier | 5 | +--------------------------------+-----------------------------+ | BGP MultiHop | 4 | +--------------------------------+-----------------------------+ | MaxPaths | 8 | +--------------------------------+-----------------------------+ | AllowAsIn | 0 | +--------------------------------+-----------------------------+ | MTU | 9216 | +--------------------------------+-----------------------------+ | IPMTU | 9100 | +--------------------------------+-----------------------------+ | MCT Link IP Range | 10.20.20.0/24 | +--------------------------------+-----------------------------+ | MCT PortChannel | 64 | +--------------------------------+-----------------------------+ | LACP Timeout | short | +--------------------------------+-----------------------------+ | Control Vlan | 4090 | +--------------------------------+-----------------------------+ | Control VE | 4090 | +--------------------------------+-----------------------------+ | Rack L3 Backup IP Range | 10.30.30.0/24 | +--------------------------------+-----------------------------+ | Rack Underlay EBGP Peer Group | underlay-ebgp-group | +--------------------------------+-----------------------------+ | Rack Overlay EBGP Peer Group | overlay-ebgp-group | +--------------------------------+-----------------------------+ | Rack L3 backup port | 0/48 | +--------------------------------+-----------------------------+ | Rack MCT Ports | 0/46,0/47 | +--------------------------------+-----------------------------+
