Minimum number of links per port-channel indicates the least number of links that need to be operationally UP. This indicates the number of port-channel as operationally UP. You can provide an optional "min-link-count" per EFA port-channel during PO create and PO update operations, which gets configured on the SLX port-channel.
Default value of min-link-count for a port-channel is 1, which is same as the SLX
                default value. Update the min-link-count attribute value using min-link-count
                operation. EFA validates the po-member-port-count >= po-min-link-count per
                device.
During upgrade from EFA 2.3.0 to EFA 2.4.0 or EFA 2.5.0, the min-link-count for the port-channels is set to the default value 1.
efa tenant po create --name <po-name> --tenant <tenant-name> --description <po-description>
        --speed <100Mbps|1Gbps|10Gbps|25Gbps|40Gbps|100Gbps> --negotiation <active|passive|static>
	 --port <list-of-po-members> --min-link-count <min-link-count>
        --number <po-number> --lacp-timeout <short|long>
                efa tenant po update --name <po-name> --tenant <tenant-name>
         --operation <port-add|port-delete|lacp-timeout|description|min-link-count>
         --port <list-of-po-members> --lacp-timeout string <short|long> --min-link-count <min-link-count>
efa tenant po create --name ten1po1 --tenant ten1 --port 10.20.246.15[0/1-2],10.20.246.16[0/1-2] --speed 10Gbps --negotiation active --description tenant1po1 --min-link-count 2 efa tenant po create --name ten1po2 --tenant ten1 --port 10.20.246.15[0/3],10.20.246.16[0/3] --speed 10Gbps --negotiation active efa tenant po update --name ten1po1 --tenant ten1 --operation port-delete --port 10.20.246.15[0/1],10.20.246.16[0/1] --min-link-count 1 efa tenant po update --name ten1po1 --tenant ten1 --operation port-add --port 10.20.246.15[0/1],10.20.246.16[0/1] --min-link-count 2 efa tenant po update --name ten1po1 --tenant ten1 --operation min-link-count --min-link-count 1 efa tenant po update --name ten1po1 --tenant ten1 --operation min-link-count --min-link-count 2 efa tenant po show +---------+--------+----+--------+-------------+----------+---------+---------------------+------------+-------------+-------------+ | Name | Tenant | ID | Speed | Negotiation | Min Link | Lacp | Ports | State | Dev State | App State | | | | | | | Count | Timeout | | | | | +---------+--------+----+--------+-------------+----------+---------+---------------------+------------+-------------+-------------+ | ten1po1 | ten1 | 1 | 10Gbps | active | 2 | long | 10.20.246.15[0/1-2] | po-created | provisioned | cfg-in-sync | | | | | | | | | 10.20.246.16[0/1-2] | | | | +---------+--------+----+--------+-------------+----------+---------+---------------------+------------+-------------+-------------+ | ten1po2 | ten1 | 2 | 10Gbps | active | 1 | long | 10.20.246.15[0/3] | po-created | provisioned | cfg-in-sync | | | | | | | | | 10.20.246.16[0/3] | | | | +---------+--------+----+--------+-------------+----------+---------+---------------------+------------+-------------+-------------+
