Configure NTP at Device and Fabric Levels
Use the native commands to configure the NTP server on the SLX device. The configuration is persisted in the EFA database. DRC is supported.
  1. Run the efa inventory device ntp server create command to create an NTP server.
    efa inventory device ntp server create ?
    Flags:
          --ip string        Comma separated range of device IP addresses.
          --ntp-ip string    NTP server IP address
          --auth-key int Authentication key ID. Values 1 to 65535
          --auth-key-name string Key name
          --encryption-type string Encryption type. Valid values are md5, sha1
          --trusted-key bool Trusted key.
          --fabric string    fabric name.
    -h, --help             help for ntp
    Example:
    efa inventory device ntp server create –ntp-ip 3.3.3.3 –-auth-key 1 –-auth-key-name ntpsecret –-encryption-type md5 –trusted-key  –-ip 10.20.246.10
    efa inventory device ntp server create –ntp-ip 3.3.3.3 –-auth-key 1 –-auth-key-name ntpsecret –-encryption-type md5 –trusted-key  –-fabic clos_fabric
  2. On the SLX device, verify the NTP configuration.
    SLX# show running-config ntp
    ntp authentication-key 1 md5 $9$750C7e0ayuI31YUga1Clmg== encryption-level 7
    ntp authenticate
    ntp server 3.3.3.3 key 1
  3. Run the efa inventory device ntp server delete command to delete an NTP server.
    efa inventory device ntp server delete ?
    Flags:
    Example:
    efa inventory device ntp server delete –-ntp-ip 3.3.3.3 –-ip 10.20.246.10
    efa inventory device ntp server delete –-ntp-ip 3.3.3.3 –-fabric clos_fabric
  4. Run the efa inventory device ntp server list command to display the list of NTP servers configured using EFA.
    efa inventory device ntp server list ?
    Flags:
    Example:
    efa inventory device ntp server ntp server list –-ip 10.20.246.10
    efa inventory device ntp server ntp server list –-fabric clos_fabric
  5. Run the efa inventory device ntp disable-server command to disable SLX acting as an NTP servers to other clients. SLX cannot be an NTP server to other hosts.
    efa inventory device ntp disable-server ?
    Flags:
          --enable           Disable ntp server. Valid values are yes/no.
          --list             List disable-server on devices.
