Configure L3-Hand-Off EPG and BGP Peer under Ownership of Shared Tenant
L3-Hand-Off endpoint groups (EPG) created under the ownership of Shared Tenant are exclusively meant for the handoff of the Shared VRF. You cannot create the Extension EPGs under the ownership of Shared Tenant. BGP peer created under the ownership of Shared Tenant are exclusively meant for the handoff of the Shared VRF.
  1. Configure Shared Tenant.
    efa tenant create --name <epg-name> --type shared --port <port-list>
                     --vrf-count <num-of-vrfs> --l3-vni-range <l3-vni-range>
                     --vlan-range <vlan-range> --l2-vni-range <l2-vni-range>
  2. Configure Shared VRF under the ownership of Shared Tenant.
    efa tenant vrf create --name <vrf-name> --tenant <shared-tenant-name>
  3. Configure L3-hand-off EPG under the ownership of Shared Tenant using the Shared VRF.
    efa tenant epg create --name <epg-name> --type l3-hand-off --tenant <shared-tenant-name-owning-the-shared-vrf>
                     --po <po-list> --switchport-mode <trunk|access> --ctag-range <ctag-range>
                     --local-ip <ctag,device-ip:local-ip> --vrf <shared-vrf-owned-by-shared-tenant>
  4. Configure BGP peer under the ownership of Shared Tenant using the Shared VRF.
    efa tenant service bgp peer create --name <bgp-peer-name> --tenant <shared-tenant-owning-the-shared-vrf>
                     --ipv4-uc-nbr <device-ip,shared-vrf-owned-by-shared-tenant:bgp-peer-ip,bgp-peer-remote-asn>
