Update anycast-ip on an Existing Tenant Network
You can add or delete anycast-ipv4 and anycast-ipv6 to or from an existing tenant network using the endpoint group (EPG) update anycast-ip-add or delete operations on an L3 EPG.
  • You can provide ipv6 nd attributes (ipv6 nd mtu, ipv6 nd prefix, ipv6 nd m or o flags) along with anycast-ipv6 during anycast-ip-add operation.
  • You can provide only one anycast-ipv4 and one anycast-ipv6 per tenant network even though SLX supports multiple anycast-ipv4 or ipv6 per VE.
Typical usage of the API from Openstack Integration is as follows:
  1. EPG create with a ctag.
  2. EPG update port-group-add with endpoints (po or phy).
  3. EPG update vrf-add with anycast-ipv4.
  4. EPG update anycast-ip-add with anycast-ipv6.
  1. Add anycast-ip on existing EPG tenant network.
    efa tenant epg update --name <epg-name> --tenant <tenant-name>
                    --operation <anycast-ip-add | anycast-ip-delete>
                    --anycast-ip <ctag:anycast-ipv4> --anycast-ipv6 <ctag:anycast-ipv6>
    efa tenant epg show --detail
    Tenant        : vlanTen1
    Description   :
    Type          : extension
    Ports         : 10.20.246.15[0/1]
                  : 10.20.246.16[0/1]
    POs           :
    Port Property : switchport mode     : trunk
                  : native-vlan-tagging : false
    NW Policy     : ctag-range          : 11
                  : vrf                 : ten1vrf1
                  : l3-vni              : 8188
    Network Property [Flags : * - Native Vlan]
    | Ctag | L2-Vni | Anycast-IPv4 | Anycast-IPv6 | BD-name | Local IP (Device-IP->Local-IP) |    Ctag-Description     | Mtu-IPv6-ND | ManagedConfig-IPv6-ND | OtherConfig-IPv6-ND |  Dev-state  |  App-state  |
    | 11   | 11     | 10.0.11.1/24 |              |         |                                | Tenant L3 Extended VLAN |             | False                 | False               | provisioned | cfg-in-sync |
    efa tenant epg update --name ten1epg1 --tenant vlanTen1 --operation anycast-ip-add --anycast-ipv6 11:10::1/123
    Tenant        : vlanTen1
    Description   :
    Type          : extension
                  : 10.20.246.16[0/1]
    POs           :
                  : vrf                 : ten1vrf1
                  : l3-vni              : 8188
    | 11   | 11     | 10.0.11.1/24 | 10::1/123    |         |                                | Tenant L3 Extended VLAN |             | False                 | False               | provisioned | cfg-in-sync |
  2. Delete anycast-ip on existing EPG tenant network.
    efa tenant epg update --name ten1epg1 --tenant vlanTen1 --operation anycast-ip-delete --anycast-ipv6 11:10::1/123
    efa tenant epg show
    Tenant        : vlanTen1
    Description   :
    Type          : extension
                  : 10.20.246.16[0/1]
    POs           :
                  : vrf                 : ten1vrf1
                  : l3-vni              : 8188
    | Ctag | L2-Vni | Anycast-IPv4 | Anycast-IPv6 | BD-name | Local IP (Device-IP->Local-IP) | Mtu-IPv6-ND | ManagedConfig-IPv6-ND | OtherConfig-IPv6-ND |  Dev-state  |  App-state  |
    | 11   | 11     | 10.0.11.1/24 |              |         |                                |             | False                 | False               | provisioned | cfg-in-sync |
    For 'unstable' entities, run 'efa tenant po/vrf show' for details
