You can use various commands and scripts to verify the status of the EFA system, to help troubleshoot, and to view details of EFA nodes, PODs, and services.
device# show efa status
       NAME   STATUS   ROLES    AGE     VERSION
	TPVM   Ready    primary   6m59s   v1.14.5-k3s.1
	admin@10.24.51.226's password:
	NAME                            READY  	STATUS    RESTARTS   AGE
	pod/godb-service-wk57h          1/1     	Running  0          6m11s
	pod/gofabric-service-8v8b2      1/1     	Running  3          6m12s
	pod/goinventory-service-4kggf   1/1     	Running  3          6m12s
	pod/gotenant-service-xcqf6      1/1     	Running  3          6m12s
	pod/rabbitmq-0                  1/1     	Running  0          6m12s
	pod/rabbitmq-1                  1/1     	Running   0         4m51s
                        On a multi-node installation:
+-----------+---------+--------+---------------+ | Node Name | Role | Status | IP | +-----------+---------+--------+---------------+ | tpvm2 | active | up | 10.20.216.242 | +-----------+---------+--------+---------------+ | tpvm1 | standby | up | 10.20.216.241 | +-----------+---------+--------+---------------+ --- Time Elapsed: 4.277420974s ---
On a single-node installation:
+-----------+--------+--------+-------------+ | Node Name | Role | Status | IP | +-----------+--------+--------+-------------+ | efa | active | up | 10.21.90.43 | +-----------+--------+--------+-------------+ --- Time Elapsed: 1.461512261s ---
# k3s kubectl get pods -n efa NAME READY STATUS RESTARTS AGE goswitch-service-958fcfb4f-qddnw 1/1 Running 4 72d godb-service-57bd99747-f4cxb 1/1 Running 4 83d efa-api-docs-6bb5dbcc74-br485 1/1 Running 4 72d filebeat-service-86ddd654b6-z9zhr 1/1 Running 4 72d goopenstack-service-554c57548f-bjwtb 1/1 Running 8 72d rabbitmq-0 1/1 Running 7 72d govcenter-service-f6b49d9b9-s24wk 1/1 Running 19 72d gohyperv-service-854654f6b9-m9mv8 1/1 Running 20 72d goinventory-service-59d9b798d8-s9wn6 1/1 Running 20 72d gotenant-service-55fd8889d8-g8rgb 1/1 Running 19 72d gofabric-service-69d8995fc6-swnqw 1/1 Running 19 72d metricbeat-service-76c4874887-mbm7h 1/1 Running 32 72d
$ systemctl status hostauth.service
hostauth.service - OS Auth Service
Loaded: loaded (/lib/systemd/system/hostauth.service; enabled; vendor preset: enabled)
Active: active (running) since Thu 2020-04-23 07:56:20 UTC; 23 h ago
Main PID: 23839 (hostauth)
Tasks: 5
CGroup: /system.slice/hostauth.service
        23839 /apps/bin/hostauth
Apr 23 07:56:20 tpvm2 systemd[1]: Started OS Auth Service
