Upgrade Spine in CLOS
  1. Enabling maintenance mode on a spine also involves BGP. The graceful_shutdown parameter will be sent out to all the spine‘s underlay neighbors (all leafs in the pod and super-spines). The neighbors will no longer send traffic to the first spine going into maintenance mode and redirect traffic to an alternate path.
  2. The running-configuration is saved on the first spine to preserve all current configurations including the maintenance mode enable configuration.
  3. The firmware on the first spine can now be upgraded and rebooted for firmware activation without traffic loss.
  4. After the firmware is upgraded, the maintenance mode is disabled to allow traffic again through the upgraded spine.
  5. The running-config is saved again to ensure the maintenance mode config remains disabled.
    The same process can be carried out on the second spine to upgrade the firmware without traffic loss.
    First spine firmware upgrade with maintenance mode
    Second spine firmware upgrade with maintenance mode
