You can replace a device that has the same configuration as the new device without affecting the network or the configuration.
efa inventory device replace ip -10.x.x.x | ID | IP Address | Host Name| Model| Chassis Name| Firmware | ASN | Role | Fabric | ------------------------------------------------------------------------------------- | 7 | 10.x.x.x | Fre-135 | 3001 | BR-SLX9140 | 18s.1.01a| 65000 | | |
Key Reason
Interface IPs Updated Interface ethernet 0/5 has IP 1.1.1.1/31 but no previous IP
was assigned for device 10.x.x.x
VRF Interface Mapping Added true
Key Reason
Local AS updated
Interface IPs Updated Interface ethernet 0/28 has IP 10.10.10.56/31 but no
previous IP was assigned for device 10.x.x.x. Interface ethernet
0/25:1 has IP 10.10.10/85/31 but no previous IP was assigned for
device 10.x.x.x
Added Interfaces loopback 1
Global Added 64512
VRF updated true
