Upgrade EFA on TPVM
If a new version of the SLX firmware is required or if no SLX firmware is present, the EFA .tar file must be copied to the /efaboot directory.
  1. Verify that TPVM is set up for EFA deployment.
    • Validate that TPVM is running
      # show tpvm status
    • Validate that TPVM has an assigned IP address
      # show tpvm ip-address
    • Validate that the SSH keys are uploaded
      # show tpvm status
    • Validate that passwordless access is configured
      # show tpvm status
  2. Determine whether more than one EFA version is available in the SLX /efaboot directory.
    1. If no version is available, the installer stops
    2. If more than one version is available, you have the option to pick a version
    3. If only one version is available, the installer picks up that version
  3. Determine whether the TPVM already has a version of EFA installed.
    1. If the same version is already installed, the installer stops
    2. If no EFA is installed, the installer continues with installation
    3. If a different version is detected, the upgrade or downgrade will continue, depending on the detected version.
  4. Copy the EFA tar file to SLX (only if SLX firmware upgrade is required).
    # start-shell
    # cd /efaboot
    # scp <efa-bundle
  5. Deploy EFA on TPVM from SLX.
    # efa deploy
  6. Verify the status of deployed EFA.
    # show efa status
