efa fabric import
Imports a fabric.
Syntax
efa fabric import
Command Default
If efa.db (Embedded fabric DB file) is available on the host where EFA application is run then it can be imported by providing the local file path. In this case server IP and server credentials are not required.
If efa.db is present on the TPVM user has to provide the db file path on TPVM for e.g /var/efa/efa.db. Also, user needs to enter the TPVM server IP address and server credentials.
If db file path is incorrect or if the application is unable to open the db file then an appropriate error is returned.
If connection to TPVM server fails or unable to locate the DB file using the remote file path then an appropriate error is returned to the user.
Parameters
db-file
EFA dbfile name including full path
fabric-name
Name with which fabric will get imported in the EFA
server-ip
Remote server IP
username
Remote server username
password
Remote server password
Local DB file import
efa fabric import --db-file /root/efa/efa.db --fabric-name default
Successfully imported fabric to EFA
Remote DB file import
efa fabric import --db-file /var/efa/efa.db --fabric-name efa_fabric –server-ip 10.24.85.180 –username admin–password password
 Leaf Device 10.25.225.172 not connected to Spine Device
        10.24.80.137 [Failed]
 Spine Device 10.24.80.137 not connected to Leaf Device
        10.25.225.172 [Failed]
