efa fabric execution show
Displays the REST API executions of Fabric service.
Syntax
efa fabric execution show [ -id execution id | -limit number of executions | -status failed | succeeded | all ]
Parameters
id
Filter the executions based on the execution id. "Limit" and "status" flags are ignored when the "id" flag is given.
-limit
Limit the number of executions to be listed. A value of "0" lists all the executions. The default is 10.
-status
Filter the executions based on the status (failed/succeeded/all). The default is "all".
