CLOS Fabric with Non-auto VNI Map
Auto VNI simplifies the mapping IDs by using the VLAN ID as the VNI ID (i.e. VLAN 100 = VNI 100). This works well in environments where overlapping VLANs are not being used. However, if two different tenants are using VLAN 100, VNI 100 cannot be used by both. At this point, manual mapping of VLAN to VNI is required. Extreme Fabric Automation simplifies this by allowing VNI ranges for tenants to automate “manual” mapping to work for overlapping VLANs.
The following figure shows 3-stage CLOS topology.
3-stage CLOS Topology
The following figure shows tenant constructs in CLOS fabric.
Scope of Tenant Constructs in Fabric
