Supported Non-Clos Topologies
Several small data center, non-Clos topologies are supported.
Each rack consists of 2 devices connected to each other via eth 0/46, eth 0/47, and eth 0/48. Devices in a rack form MCT (multi-chassis trunking).
Table 1. Items in a rack
Items Description
Intra-rack links eth 0/46 and eth 0/47 are used for MCT and eth 0/48 is used for Layer 3 backup link
Inter-rack links Links that interconnect the racks, also called fabric links
IBGP IPv4 neighbor Established on the Layer 3 backup link
IBPG Layer 2 VPN EVPN neighbor Established between the MCT nodes
EBGP IPv4 neighbors Established on the Fabric links
EBGP Layer 2 VPN EVPN neighbors Established from every node of every rack to every other remote rack node. The remote neighbor IP address is the remote device router ID.
Supported small data center topologies
Four small data center topologies are supported: single rack, two racks, three racks, and four racks.
Small data centers are supported on SLX 9140, SLX 9150, and SLX 9250.
Non-Clos multi-rack config automation
