efa fabric settings update
Updates the fabric settings to overwrite the “default” fabric settings.
Syntax
efa fabric settings update [ --attribute-type <attribute-value> ]
Parameters
--mtu
The MTU size in bytes <Number:1548-9216>. The default value is 9216.
--ip-mtu
IPV4/IPV6 MTU size in bytes <Number:1300-9194>. The default value is 9100.
--bfd-enable
BFD enabled Yes/No. The default value is NO.
--bfd-tx
BFD desired min transmit interval in milliseconds <NUMBER: 50-30000>. The default value is 300.
--bfd-rx
BFD desired min receive interval in milliseconds <NUMBER: 50-30000>. The default value is 300.
--bfd-multiplier
BFD detection time multiplier <NUMBER: 3-50>. The default value is 3.
--bgp-multihop
Allow EBGP neighbors not on directly connected networks <Number:1-255>. The default value is 2.
--max-paths
Forward packets over multiple paths<Number:1-64>. The default value is 8.
--allow-as-in
Disables the AS_PATH check of the routes learned from the AS<Number:1-10>. The default value is 1.
--p2p-link-range
IP Address Pool to be used for Leaf to Spine links. The default value is 10.10.10.0/23.
--loopback-ip-range
IP Address Pool for Loopback interface, to be used for unnumbered and VTEP IP. The default value is 172.31.254.0/24.
--rack-l3-backup-ip-range
IP Address Pool for L3 Back up. The default value is 10.30.30.0/24.
--loopback-port-number
Loopback ID on the device to be used as donor IP interface for the link between Leaf and Spine. The default value is 1.
--vtep-loopback-port-number
Loopback ID on the device to be used as VTEP IP interface. The default value is 2.
--leaf-asn-block
ASN pool for Leaf nodes. The default value is 65000-65534.
--spine-asn-block
ASN pool for Spine nodes. The default value is 64512-64768.
super-spine-asn-block
ASN pool for Super-spine nodes. The default value is 64769.
--rack-asn-block
ASN Pool For Rack Nodes. The default value is 4200000000-4200065534.
--leaf-peer-group
Leaf Peer Group Name <WORD: 1-63>. The default value is leaf-group.
--spine-peer-group
Spine Peer Group Name <WORD: 1-63>. The default value is spine-group.
--super-spine-peer-group
Super-spine Peer Group Name <WORD: 1-63. The default value is spine-group.
--rack-underlay-ebgp-peer-group
Rack Underlay EBGP Peer Group Name <WORD: 1-63>. The default value is underlay-ebgp-group.
--rack-overlay-ebgp-peer-group
Rack Overlay EBGP Peer Group Name <WORD: 1-63>. The default value is overlay-ebgp-group.
--anycast-mac-address
IPV4 ANY CAST MAC address.mac address HHHH.HHHH.HHHH. The default value is 0201.0101.0101.
--ipv6-anycast-mac-address
IPV6 ANY CAST MAC address.mac address HHHH.HHHH.HHHH. The default value is 0201.0101.0102.
--mac-aging-timeout
MAC Aging Timeout <NUMBER: 0|60-100000>. The default value is 1800.
--mac-aging-conversation-timeout
MAC Conversational Aging time in seconds<NUMBER: 0|60-100000>. The default value is 300.
--mac-move-limit
MAC move detect limit <NUMBER: 5-500>. The default value is 20.
--duplicate-mac-timer
Duplicate Mac Timer. The default value is 5.
--duplicate-mac-timer-max-count
Duplicate Mac Timer Max Count. The default value is 3.
--mctlink-ip-range
IP Address Pool to be used for MCT peering. The default value is 10.20.20.0/24.
--mct-port-channel
Portchannel interface ID <NUMBER: 1-64> to be used as MCT peer-interface. The default value is 64.
--rack-l3-backup-port
Rack L3 Backup port <STRING: default '0/48'>to be used as rack 13 backup port. The default value is 48.
--rack-mct-ports
Rack MCT Port <STRING: default '0/46,0/47'>to be used as rack MCT port.
--rack-ld-l3-backup-port
Rack Low Density L3 Backup port (not applicable to SLX-9250) <STRING: default '0/32'>to be used as rack low density L3 backup port.
--rack-ld-mct-ports
Rack Low Density MCT Ports <STRING: default '0/30,0/31'>to be used as rack low density MCT port.
--control-vlan VLAN ID <NUMBER: 1-4090>
VLAN ID to be used as MCT cluster control VLAN. The default value is 4090.
--control-ve VE ID <NUMBER: 1-4090>
VE ID to be used as MCT cluster control VE. The default value is 4090.
--configure-overlay-gateway
ConfigureOverlayGateway Enabled Yes/No. The default value is Yes.
--vni-auto-map
VTEP VLAN/BD to VNI Mode Auto (Yes/No). The default value is Yes.
