efa tenant po update
Updates a portchannel.
Syntax
efa tenant po update [ -- name po-name | --tenant tenant-name | --operation port-add | port-delete | --port port-list ]
Parameters
name portchannel name
Specifies portchannel.
tenant tenant name
Specifies tenant name.
operation operation name
Adds or deletes operation on the ports. Valid options are port-add | port-delete.
port value
Specifies device ip along with ethernet port details. Example: SW1_IP [0/1], SW2_IP[0/5]
efa tenant po update --name po1115 --tenant tenant11 --operation port-add --port 10.24.85.76[0/15]
efa tenant po update --name po1115 --tenant tenant11 --operation port-delete --port 10.24.85.76[0/15]
