efa fabric device remove
Removes existing device from a fabric.
Syntax
efa fabric device remove { --name <fabric-name> | --ip <list-of-device-ips> }| [--no-device-cleanup]
Command Default
If the “--no-device-cleanup” option is used, the configuration pushed by the automation engine will not be cleaned up from the fabric devices. Removal of a device from fabric doesn‘t delete the device from inventory. The device from inventory must be deleted.
Parameters
--name
Name of the fabric
ip
Device IP
--no-device-cleanup
Do not clean up the configuration on the devices
efa fabric device remove --ip 10.24.48.131,10.24.51.135,10.25.225.58,10.24.51.131,10.24.80.139
 --name BLR_FABRIC --no-device-cleanup
