efa tenant create
Creates tenant reserved resources like total number of L3 VNIs, VLANs, VRFs, and Bridge Domains for fabrics with non-auto VNI settings which can later be applied to an end point group.
Syntax
efa tenant create [ --name tenant-name | -- description tenant-description | --l2-vni-start value | --13-vni-start value | --vlan-range value | --vrf-count value | --enable-bd |port list of ports ]
Parameters
name tenant name
Name of the tenant.
description tenant description
Describes the tenant.
l2-vni-start value
Contiguous Range of L2 VNIs in ascending order starting from l2-vni-start will be reserved for the tenant within the scope of a fabric.
l3-vni-start value
Contiguous Range of L3 VNIs in ascending order starting from l3-vni-start will be reserved for the tenant within the scope of a fabric.
vlan-range value
Range of Vlans to be reserved for the tenant.
vrf-count int32 value
Number of VRFs reserved for the tenant.
enable-bd
Enable BD capability for networks created under this tenant.
port value
List of physical ports of devices which will be reserved for the asset. Example SW1_IP[0/1],SW2_IP[0/5].
efa tenant create --name vPOD1 --vrf-count 10 --vlan-range 2-4090 --port 172.31.254.13 [0/1],172.31.254.20 [0/1], --description Subscriber1
