efa tenant epg delete
Deletes an End Point Group (epg)
Syntax
efa tenant epg delete --name --force true/false --tenant tenant name
Parameters
--name
EPG name or comma separated EPG names to be deleted.
--force
Forces the deletion of any underling End Point Group tied to the tenant.
ny EPG tied to a tenant should first be deleted before attempting to delete the tenant, as this removes any port level configurations on the switch that are defined by the EPG. Failure to do this will result in EFA returning an error, however using the –force option will override this error and delete the underlying EPG‘s configuration on the switch
--tenant
Tenant name
Usage Guidelines
The following example deletes epg 11 on tenant 11.
efa tenant epg delete --name epg11 --tenant tenant11
