efa fabric debug push-config
Pushes the configuration for the device from the fabric.
Syntax
efa fabric debug push-config [ -device device ip | -name fabric name ]
Command Default
If the device is not mentioned, the configuration for the entire fabric is Re-push.
Parameters
device
A comma separated list of Device IP addresses for which config needs to Re-push
name
Name of the fabric to which the device belongs
efa fabric debug push-config --device 10.25.225.58--name BLR_FABRIC
