Use this task to configure the device interface.
| Field | Description |
| Network Allocation | An IP subnetwork configuration. |
| VLAN Attribute | A VLAN attribute, which can be created from within the Network Policy Switching > VLAN Attribute Section. |
| IPv4 Address / Subnet Mask | The assigned device IP Address. |
| Routing Instance | The device routing instance. |
| IPv4 Forwarding | Toggle ON to enable IPv4 forwarding. |
| VLAN Loopback Enable | Select the check box to enable VLAN loopback. |
| DHCP Relay | To override DHCP Relay, toggle ON Enable DHCP Relay. If enabled, enter a Primary DHCP Server and an optional Secondary DHCP Server. |
