Use this task to configure IP4 Static Routes for the selected device.
| Field | Description |
| Static Route Name | The name of the Static Route. |
| Destination Subnet | The desired subnet, such as 10.1.0.0/16. |
| Next Hop IP | The desired IP Address for the next Hop, such as 123.321.132.312. |
| Next Hop IP Ping Protection | Enable or Disable Next Hop IP Ping Protection. Note: Enabling
Ping Protection will generate a Ping Protection Status
tool tip when viewing your device within Manage > Devices > Monitoring > Routing.
| Metric | The desired metric value. |
| Routing Instance | Shows the Routing Instance. |
