Install Internal Power Supplies
If your switch does not come with an installed power supply, you can install one or two power supplies. All installed power supplies must blow air in the same direction and must match the airflow direction of the installed fan modules. VSP 4900 Series switches are only available with front-to-back airflow.
For installation instructions, see Replace Power Supplies.
