The VIM5-4YE versatile interface module provides four 25-GbE (SFP28) LRM/MACsec capable ports.
For VSP4900-24S and VSP4900-48P only the first two 25-GbE (SFP28) ports are supported. The second two 25-GbE (SFP28) ports are reserved.
You must set sys vim-speed to 10G or 25G for VIM5-4YE. The default is 25G. A reboot is not necessary after setting the speed. For details about the sys vim-speed command, see the Command Line Interface Commands Reference for VOSS.
For information about the supported optical modules, refer to the most recent version of the Extreme Optics website.
ExtremeSwitching VSP 4900 port number for VSP4900-24S and VSP4900-48P |
ExtremeSwitching VSP 4900 port numbers for VSP4900-24XE, and VSP4900-12MXU-12XE |
2/1, 2/2 |
2/1, 2/2 |
