VSP 4900 Series switches support the following fan module:
Before you begin, have the replacement fan module on hand so that you can complete the replacement promptly. The switch can overheat if left without adequate cooling for an extended time.
Use the following instructions to remove a fan module.
The fan module is held in place by spring clips. As you pull, the clips disengage and the fan stops.
Use the following instructions to install a fan module.
Fan modules with a red tab provide front-to-back airflow and are labeled Air Out.
Do not force the installation. If the fan assembly does not slide in easily, ensure that it is correctly oriented before continuing.Push until the fan module snaps into place. The fan automatically starts to operate.
